Author: Subject: High Amp connector advice.
Irony
posted on 12/7/11 at 10:49 AM Reply With Quote
I am ploughing through the electrics on my kitcar build and I must say I reckon I have got my head around it.
My ignition switch has long tails hanging from it and I want to connect it to the main loom etc. As no-one can seem to give me absolute answers on the max ampage of yellow crimp connectors (different people have told everything from 15amps to 45amps) I was looking for a connector that can take a reasonable ampage suitable for a switched ignition cable. Any suggestions?
daviep
posted on 12/7/11 at 11:02 AM Reply With Quote
Define "reasonable" or just tell us how much you need.
Davie
“A truly great library contains something in it to offend everyone.”
posted on 12/7/11 at 11:22 AM Reply With Quote
Crimped spade (or bullet) connectors will be fine provided you use the correctly sized ones for the (correctly sized) cable. A neater option than a pile of loose cables/connectors are the housed crimp terminals typically in 2, 4, 6, 8 way format. Have a look at Vehicle Wiring Products catalouge/website if you haven't already, there's a good range to choose from.
Irony
posted on 12/7/11 at 11:24 AM Reply With Quote
I haven't sat down and worked it out. I have a Rover V8 running Megajolt and everything else on the car is more or less standard. I plan to run the Headlights (main and dip), radiator fan, horn, fuel pump and 12v outlet through relays. So the switch ignition will take more or less everything else.
matt_gsxr
posted on 12/7/11 at 02:29 PM Reply With Quote
There isn't that much left.
Instruments are < 1Amp total
Injectors might be 900mA each (high impedance) this would be 100% duty cycle
Ignition will depend on what you have used
Rear lights are 1Amp (for both)
Brake lights are 2Amps each
Side lights are 2Amps (for all 4)
For light 2Amps
Reversing lights (no idea)
Heater fan? (not sure of the load on that as I don't have one).
Definitely worth doing some simple calculations of what you need. If you don't already know for current (Amps) take power (in W) and divide by 12V.
I'd be surprised if you get to 15Amps.
Matt
