Author: Subject: Starter motor
ChrisLeary
posted on 21/7/11 at 09:47 AM Reply With Quote
Starter motor
Hi all,
How is everyone?
The starter motor gave up on me on the journey home from picking up an L reg 2.0l zetec powered 7 yesterday.
Its a silvertop with Mt75 box, which starter will fit the car and does anyone have one spare?
Thanks in advance,
Chris
Strontium Dog
posted on 21/7/11 at 10:28 AM Reply With Quote
Check the output wiring from the alternator as it probably feeds the power to the starter motor (the same cable is often shared and is the thick heavy one). You may find it is just a bad connection on the starter motor that is causing you both of the faults you are getting! The post that the cable attaches to on the starter motor solenoid can let go if iyt has over heated or been tightened too much or you may just have loose terminations!
[Edited on 21/7/11 by Strontium Dog]
http://s187.photobucket.com/albums/x319/zephyr2000/General%20forum%20uploads/?action=view¤t=3DEngine.mp4
David Jenkins
posted on 21/7/11 at 10:32 AM Reply With Quote
Considering the problems you're experiencing, I'd check all your earth connections as well as the battery & starter leads - battery to chassis, & engine to chassis (as well as what S-D recommends above).
britishtrident
posted on 21/7/11 at 11:21 AM Reply With Quote
First port of call is always the battery terminals - give them clean.
ChrisLeary
posted on 21/7/11 at 02:10 PM Reply With Quote
I've had a look between the starter and the alternatore and it doesn't look like there's a direct connection.
If the post on the starter has gone which starter will be a replacement?
Chris
big_wasa
posted on 21/7/11 at 04:21 PM Reply With Quote
lucas lr707 or look at the numbers on yours as ther others that will fit.
As above check out the wiring before spending your cash.
