Author: Subject: Escort indicator pin thingies
pekwah1
posted on 18/1/12 at 01:10 PM Reply With Quote
Hi Guys,
Just a quick one...
Anyone know what the two sprung brass pins on this indicator unit are for?
[Edited on 18/1/12 by pekwah1]
owelly
Horn contacts for the steering wheel?
http://www.ppcmag.co.uk
pekwah1
posted on 18/1/12 at 01:12 PM Reply With Quote
that's what i thought it might be but they're usually on the column itself??
steve m
posted on 18/1/12 at 02:29 PM Reply With Quote
I thought horn conectors as well, is there two copper rings on the inside of your steering wheel?
Could they be airbag connectors?
pekwah1
posted on 18/1/12 at 02:33 PM Reply With Quote
hmmm... thought as much.
I think i'll just ignore them then, it's a different indicator unit from the ignition housing, mine already has the horn thingies on the wheel and igntion housing.
Maybe i should just get the correct indicator switch unit....!
scudderfish
posted on 18/1/12 at 02:35 PM Reply With Quote
Is there continuity between them? Is there continuity between them and any of the pins on the rear? If you put 12v through them, where does the smoke come out?
Michael
posted on 20/1/12 at 10:44 PM Reply With Quote
I think they are horn contact, as I replaced one on dads P reg escort about 10 years ago and the horn sounded putting it in.
I have the similar on my MK2 Astra switch gear on my locost, but just one at the top.
