lewis
posted on 18/2/12 at 04:22 PM |
EDIS rpm output?
Is there a rpm output on a EDIS unit? I want to test my rev counter to see if it's that or my megajolt that's not working(no rpm on taco)
or can I put a multimeter on the taco signal wire to the gauge (I presume rpm signal is voltage pulses??) cheers Lewis.
I am a driving god!..........sort of
lotusmadandy
posted on 18/2/12 at 05:03 PM |
Yes there is a tacho output on an edis,
although the connector is not on every plug.
It is on pin 11 in between the coil 1 and coil 2 wires.
I have added it to both of my edis installs,to drive the tacho.
[Edited on 18/2/12 by lotusmadandy]
lewis
posted on 18/2/12 at 05:12 PM |
Nice one thanks mate I'll bypass the megajolt and test the taco directly to see what's at fault,Lewis.
lotusmadandy
posted on 18/2/12 at 05:18 PM |
If you want to add a connector permanently,
i have several spare ones with tails on them.
U2U your details and i will send you one.
lewis
posted on 18/2/12 at 05:41 PM |
Thankyou for the offer mate,I will test the taco and let you know. Lewis.
paulf
posted on 18/2/12 at 10:05 PM |
I found that the tacho output would not always drive a tacho , I found another option was to connect the tacho to the PIP signal line which seems to
work reliably with most tachos that I tried and has no effect on the operation of the mega jolt.
Paul
lewis
posted on 18/2/12 at 10:28 PM |
Thanks Paul I will give that a go as another option.
