mcg
posted on 5/8/12 at 07:57 PM |
LED Side repeater on the blink
After a lot of messing around and testing on the indicator and hazard wiring, I have noticed one of the LED side repeater s is only flashing at half
brightness.
side repeater link
Is it possible that it is randomly buggered, or can there only be somthing wrong with my wiring? I have tested it by running 12v direct to it and its
still half brightness.
The LED repeater works perfect on the other side.
I thought LED's would be a reliable solution.
Any help would be greatly appreciated.
MAtt
pmc_3
posted on 5/8/12 at 08:05 PM |
Tried swapping them over? If the one that was half brightness still is when on the other side i'd say its fubar
loggyboy
posted on 5/8/12 at 09:10 PM |
Check the cabling as far back as you can. If all LEDs are evenly lit (or dim) then its most likely a fault with the wiring.
Mistral Motorsport
big-vee-twin
posted on 5/8/12 at 09:34 PM |
If you had it connected directly to 12volts then it will be an issue with the LED's not the wiring, you'll just have to get another one.
http://www.triangleltd.com
loggyboy
posted on 5/8/12 at 09:38 PM |
unlikely that all the leds would fail in the same way at same time, if 12v has been fed to the leads of the repeaters, theres still wiring left
leading in to and within the units that could have failed.
EDIT - having looked at the link, there may well only be 1 LED anyway, so ignore my wafflings above!!
[Edited on 5-8-12 by loggyboy]
Mistral Motorsport
gavin174
posted on 6/8/12 at 09:26 AM |
is one possibly a 24v instead of a 12v
mcg
posted on 6/8/12 at 12:00 PM |
thanks for the inputs. I will remove from the installation and check fully before sending back. Bit of a bugger as its kinda glued in but should be
fine.
Spoke to CBS and they as usual were very helpful, and said to send it back to em if it is broken. All good.
Cheers again
Matt
