Author: Subject: Wiring Problems
carlknight1982
posted on 13/10/12 at 08:08 PM Reply With Quote
Wiring Problems
My Jago Geep Uses a escort mk2 loom, im having problems with the lights and wipers ie only some are working, is there anything specific that is in the loom i need to look for?
Carl
[Edited on 13/10/12 by carlknight1982]
Logic will get you from a A to B
Imagination will take you everywhere.
stevegough
posted on 13/10/12 at 08:30 PM Reply With Quote
Earth fault on the column stalk switch blocks, - fuses? Are they switched earth or switched live? (not familiar with the escort, just the Sierra).
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
britishtrident
posted on 14/10/12 at 11:05 AM Reply With Quote
The first step is to check the power supply and earths at each lamp with a multimeter -- glass fibre bodies are very prone to earthing problems.
Is the fuse box the original Ford item with ceramic fuses ? if so the fuse box is the next suspect Escorts of this era suffered badly from corroded fuse boxes, apart from holding the fuses the fuse box on these cars acted a as a main junction box for all the electrics.
[/I]
