gucio1983
posted on 17/8/13 at 11:22 PM |
ECU Mondeo mk2 2.0 16v 98BB-12A650-BCA OUCH
Hi. Does anyone use this ecu on 2.0 zetec?? Wirings are the same as owls ecu from 1997??
big_wasa
posted on 18/8/13 at 09:18 AM |
Your 98 ecu will be from a black top so it is different to the "owls" ecu as that was last of the silver tops.
If your looking for pin outs for yours then ive posted up the info for the "owl5"
HERE You should find all the info you need there but I can not promise an exact
match.
This guys work maybe easier to understand ? Link
gucio1983
posted on 18/8/13 at 07:59 PM |
thanks @big_wasa for links. When has ford integrated alarm into ecu??
big_wasa
posted on 18/8/13 at 09:07 PM |
Alarm ?
They haven't. The immobilizer (pats) was integrated into the ecu around 1994~1995. So there are only three for the 2.0 silvertop zetec. Deep
Desk Dewy.
gucio1983
posted on 19/8/13 at 08:14 AM |
That is a good info. So I need only ecu, coil and key. I think, I give him a try. Can I wire ecu on the desk??? I want check pins and PATS.
