b3ngy
posted on 4/9/13 at 11:57 AM |
converting to toggle switches
I really want to swap out my sierra stalks and use dash mounted toggle switches. All the lights/indicators/hazards work as they should but how
difficult is it to swap to toggle switches?? Is it a relatively easy job or will it require a lot of re-wiring? My electrical knowledge isn't
great, I can carry out basic voltage and continuity checks etc.
Any help and advice appreciated.
Not Anumber
posted on 4/9/13 at 01:04 PM |
I'd stick to using the stalks. I soon got tired of using dash mounted switches and changed to stalks. Dash mounted indicators and light
switches are interesting, quirky and fine for track use but i just found them impractical for use on urban roads- flashing the lights at oncoming
traffic on mine meant leaning accross the dashboard to operate 2 switches which i found frankly a bit dangerous at times.
Installing column stalks just made the car a lot more pleasant to drive in town, they are one innovation the mainstream motor manufacturers got right.
iank
posted on 4/9/13 at 01:12 PM |
If you do it before IVA you'll need some guards like the BMW MINI has for its toggles.
Anonymous
TimEllershaw
posted on 4/9/13 at 02:10 PM |
It's not rocket science and there are plenty of wiring diagrams around to give you a clue.
With headlights you just have to think a little bit about the sequence of what to turn on first ( side -> dip - > main ) and indicators just
make sure you can't have both directions on at the same time.
Originally my car had a random selection of old toggle switches that I swapped to savage push-button switches to tidy it up a bit. I didn't mind
the lights, but indicators were rubbish, and I've now put them on a stalk.
Tim.
( slight aside : the savage switches look nice, but in reality they feel pretty rubish to press. Make sure you pick something with a solid action )
http://www.teenagecancertrust.org/
blakep82
posted on 4/9/13 at 02:42 PM |
quote: Originally posted by Not Anumber
flashing the lights at oncoming traffic on mine meant leaning accross the dashboard to operate 2 switches
I think you mean you put them in an inconvenient or the wrong place?
No you don't. If you put them in a good spot just behind the steering wheel, they'll be easy to operate, and sit in an area which is
exempt from the interior projections part of the manual.
I'm putting mine down the right hand side of the dash board, which is exempt, and reachable from the wheel without too much effort
________________________
iank
posted on 4/9/13 at 03:59 PM |
Fair enough if you manage to get them in the exempt area with readable labels, I know you're in a closed car, but I seem to remember that on
7's, they've tightened up the exempt area on the right of the wheel and all over if you've not got a windscreen as it can be reached
from outside the car so counts under the exterior projection rules.
Anonymous
steve m
posted on 4/9/13 at 04:41 PM |
"I'd stick to using the stalks. I soon got tired of using dash mounted switches and changed to stalks. Dash mounted indicators and light
traffic on mine meant leaning across the dashboard to operate 2 switches which i found frankly a bit dangerous at times.
+1
ALL the above makes complete sense, and if I was to make another dash, would go with stalks,
but then that would ruin the ethos of my car
steve
Mr Whippy
posted on 4/9/13 at 07:42 PM |
Stalk indicators have been on cars a lot longer than the 7 style car has been around. You can get some really classic looking after market ones which
will go fine with your car. Also think about a foot operated dip switch their actually quite good to use and in some ways better than a stalk switch.
