Mr Whippy
posted on 8/1/14 at 01:40 PM |
Raspberry Pi Car operating system
Hi
I’ve got hold of a Raspberry Pi B and started tinkering with it, seem’s really easy to program and stick stuff onto like sensors and displays. Help
also that I use to do programming.
Was thinking of tying it into the landy’s engine to get readouts, put a screen on the dash for the internet etc and maybe even control the engine for
fuel injection and timing etc as a project.
Has anyone here tried that kind of thing with a Pi?
loggyboy
posted on 8/1/14 at 01:48 PM |
I was thinking of it when I first heard about them. Never did it though.
Then I bought my little girl a £45 android tablet (Apptab from Asda) for christmas. After finding it a good cheap item I thought, I could just get one
of those, mount it on the dash and it will do the same as a Pi, and no need to add a screen, input etc to it.
Mistral Motorsport
deezee
posted on 8/1/14 at 02:19 PM |
The raspberry Pi forums have given up on the idea long ago. The 12v car system just won't work on the GPIO and its too slow and weak to power /
control the engine directly. The car electrical system is too noisy for the Pi to operate without loads of decoupling, again making it harder to
control anything. People do however document connecting to to OBD II for reading off data.
http://www.nikrooz.co.uk/raspberry-pi-car-puter/
Mr Whippy
posted on 8/1/14 at 02:34 PM |
Good info there thanks, had thought of quite a few uses on a car. Bit surprised about power issues seeing it's USB powered and currently I use
USB devices in my car with no probs. Will have a good read though
Did think it would also be a way of managing an electric/diesel generator hybrid system which I've wanted to build for ages but didn't
know a way of making a system to automatically control the charging and switch over.
deezee
posted on 8/1/14 at 02:58 PM |
You could use Ardiuno with more success. People have been making engine management, solar charging and automation projects for years now. You can
find lots of information. You will find that the controller is only 1 small part of the puzzle and you need a load of other parts to properly get
these things working.
A quick look on the forum shows an electric / petrol hybrid built by Yale universcity, who have made the project public domain, including the
controller coding.
I'm currently building an Arduino interface reader for a Megajolt. Based on the project by David Whitty. Thats pretty tricky. I'm OK at
coding, but need to constantly ask advice about 4050 shifters, serial interfaces and RS232 connectors.
James
posted on 8/1/14 at 03:28 PM |
Much as I love the Pi (I have a B that I use for XBMC) I think one of the biggest issues is the processor isn't fast enough for engine
management.
[Edited on 8/1/14 by James]
- Muhammad Ali
Slimy38
posted on 8/1/14 at 03:38 PM |
I have Pi and Arduino, and I find that I get more success with Arduino. It just seems more suited to IO operations.
What deezee is saying about trouble with power is not necessarily the supply to power it (5 volts is easy to generate), it's more the IO side of
things that has to be tidied up, with lots of very small very fast signals jumping around all over the place.
Mr Whippy
posted on 8/1/14 at 03:55 PM |
Will have a good look at that hybrid tonight, a lot easier if it's already been done
Great stuff cheers
matt_gsxr
posted on 8/1/14 at 04:48 PM |
Agree with most of what has been said before. I've had a play with both and built a few toys.
Arduino A/D is a bit slow and it doesn't have much processing power or the ability to display stuff, although you can add basic stuff for
display it doesn't have dedicated hardware to control a screen so is limited. Arduino has a CAN interface card available
(http://www.robotshop.com/en/can-bus-shield-arduino.html)
Rasp Pi is great at displaying (although small portable HDMI displays are more expensive than cheap tablets!*) and has more processing power. Have
you considered the "gertboard" with Rasp-pi as that adds to its IO capabilities.
Couldn't you do much of this with Android Tablet talking to the CAN bus via Serial/USB/Bluetooth, does Torques not have the functionality you
need. https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en_GB
Or is it a "project" that you are looking for.
Matt
*There is a crowdsourced project to sort this out. http://www.kickstarter.com/projects/697708033/hdmipi-affordable-9-high-def-screen-for-the-raspbe
MikeRJ
posted on 8/1/14 at 07:39 PM |
management.
It's more than fast enough, in fact the actual processor core is vastly more powerful than the micrcontroller used in most ECU's (remember
the original Megasquirt only had a slow 8 bit micro). However it doesn't have any suitable timer peripherals that would be needed (there is one
system timer for the OS, and a single very basic timer with no capture/compare options).
You also wouldn't run something like Linux in such a demanding hard real time system, even "real time Linux" is far too unwieldy and
bulky for this kind of application.
You can buy an "STM Discovery" board for around £10 that is essentially like a large Arduino, but with a powerful 32 bit ARM core
microcontroller on board that would be more than adequate to run a very comprehensive engine controller. However buying the hardware is one thing,
writing code to reliably run an engine is another!
You can now get Arduino variants with 32 bit MIPS or ARM core microcontrollers on board!
[Edited on 8/1/14 by MikeRJ]
