bi22le
posted on 30/9/14 at 11:56 AM |
Dodgy gauge reading - Oil temp. Thoughts please.
The lava hot oil temps saga boils on. . .
Previously. . Did a track day on a hot dat @ Langdow and the oil temp was bonkers hot. 140deg with water staying below 100deg. It had been slowly
creeping up and up over other track days but put it done to me spanking the car more and more as it getting better set up and im getting more
confident.
So, fitted a small oil cooler and did another baking hot day at Rockingham (I have been lucky with the weather this year). It made NO difference. Oil
temps rocket to 150, water struggles to stay below 100deg.
So, I fitted a 19 row 235mm monster oil rad and did another track day at Snetterton yesterday. Made a little difference but still getting 140deg far
too easily. I also fitted a Rally Designs ali water rad and now water sits perfect at 80deg.
What I dont get is:
1) How can I get such a big differential between oil and water temps. Yeterday I was 80deg water, 140+deg oil?
2) How can my oil be getting so hot with such a massive rad?
3) When I stop the oil temps seems to drop off pretty quickly (30+deg in 5mins), if its hot it will stay hot for a while.
3) 150deg oil is mega hot and my engine should be showing signs of wear or at least hear a rattle. Now signs at all.
Sensor is on a sandwich plate at the filter \ oil take off. Racetech or Smiths gauge. Air flow is fine, loads of ducting.
My car is kept out side 24 \ 7, could my gauge be wonkey?
Discuss!
Please read my ring story:
INDY BIRD
posted on 30/9/14 at 12:07 PM |
Could be a gauge fault do you have air cN you get your hands on a I fared heat detector with his you could check all temps etc incl tyres and get a
reality of what's going on ?
Hope you get it sorted
Sean
mcerd1
posted on 30/9/14 at 12:18 PM |
gauges can always be wrong - even when they are brand new !
the gauge could be dead but so could the sender or both
the sender might not match the gauge
the gauge might not have been correctly calibrated from new
one easy way to test the gauge is to remove the sender from the sandwich plate and place it in a liquid of known temp and see what the gauge says
boiling water at sea level is 100°C - so that should give you a pretty good reference temperature
britishtrident
posted on 30/9/14 at 12:26 PM |
I can't find a previous thread but the first thing to do is a sanity check on the gauge.
Loads of digital thermometers on ebay but most only go up to 70 or 80c
I use a cheap IR one but a mate uses a digital food probe that he bought from Sainsburys.
You could also use a pipe thermometer that has a spring that you could hook round the oil filter they go up to 120c or so which should be enough to
know if you can trust the gauge..
[Edited on 30/9/14 by britishtrident]
[/I]
bi22le
posted on 30/9/14 at 12:27 PM |
Both very good points.
Sean, Im not sure I know exactly what your talking about. Are you thinking of a IR temp gun? If so I do have one of these and was thinking of giving
it a go.
It may also be wrong but I can test it easier then testing the sensor \ gauge. You would of though gauges just work or not but following a little
searching it seems they can do all sorts of stuff.
I wanting to go to a Digidash this winter and this is one of the reasons.
Norfolkluegojnr
posted on 30/9/14 at 12:31 PM |
left field suggestion - oil pump? if you aren't getting much flow, perhaps the oil is getting very hot from lack of circulation?
EDIT: presume you're getting good pressure so thats probably a daft suggestion.....
[Edited on 30/9/14 by Norfolkluegojnr]
johnemms
posted on 30/9/14 at 12:33 PM |
I had mine on the oil sandwich plate which always came up hot quite quickly.. My thoughts were it was picking up extra heat from the engine block..
Now sensor located is on the oil sump pan - it takes quite a while for sump temp to register or show anywhere near hot..
So do you take a reading from the block?
Or take a reading from the oil in the sump?
[Edited on 30/9/14 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
INDY BIRD
posted on 30/9/14 at 01:27 PM |
Yep a ir gun I cN get my hands on one if required as my friend has one to borrow etc cheers Sean
bi22le
posted on 30/9/14 at 02:45 PM |
I get very good oil pressure so not pump or ware concerns.
unless im getting heat soak from the exhaust I doubt the block is getting hotter than the oil.
correct me if anyone knows better
MikeRJ
posted on 30/9/14 at 03:45 PM |
How good? Excessive oil pressure will put more heat into the oil.
bi22le
posted on 30/9/14 at 04:51 PM |
4 bar. Assuming that gauge is working properly. . . .
luke2152
posted on 30/9/14 at 09:27 PM |
Check your wiring connectors as bad connectors could change the resistance of the whole circuit and give incorrect reading
rgrs
posted on 1/10/14 at 10:51 AM |
Whip out the sender and stick it in boiling water, you will then prove the sender, wiring,programming etc all in one hit.
Roger
rodgling
posted on 1/10/14 at 09:38 PM |
Roger
Agreed, this will tell you 100% if it's a real problem or a sender/display problem.
