Author: Subject: Blacktop Zetec Starting Problem
pekwah1
posted on 10/1/15 at 10:01 PM Reply With Quote
Hi Guys,
I have a 2.0 blacktop in my kit running on standard ECU.
It was running fine up until a while ago.
It appears i have no spark.
The fuel pumps prime, all ignition comes on ok, and engine turns over from the key no problem.
It is fuelling as i have wet plugs, but have no spark.
I have tried replacing the coil and ECU in case of problems here, but has made no difference.
I am now convinced it is a wiring problem, but i'm not really sure what to look for.
Again everything else seems to be working fine and i'm getting no error messages on the ECU.
I guess check live feeds to the ECU and earths, but any ideas other than this?
Thanks in advance.
madteg
posted on 10/1/15 at 10:14 PM Reply With Quote
Could be crank position sensor
pekwah1
posted on 10/1/15 at 10:37 PM Reply With Quote
Would that not give an ECU error code?
Also do you know where it is? Can't seem to find out from google...
AndyW
posted on 10/1/15 at 10:38 PM Reply With Quote
Its the sensor in the block just above the starter motor
posted on 11/1/15 at 07:58 AM Reply With Quote
Are you getting any RPM signal? If not that very often points to a faulty Crankshaft Position Sensor.
ian locostzx9rc2
posted on 11/1/15 at 09:04 AM Reply With Quote
+1 for crank sensor doesn't always bring up a error code if you can see live data on a laptop or dia tool check for engine revs
19sac65
posted on 11/1/15 at 10:15 AM Reply With Quote
Also check for a feed to the middle wire of the coil pack
posted on 11/1/15 at 01:11 PM Reply With Quote
Yep, check the middle wire is live and doesn't drop out during cranking.
pekwah1
posted on 11/1/15 at 04:17 PM Reply With Quote
cheers guys,
will go have a look....
Out of interest, if i have no live signal on the middle pin to the coil, would this normally point to a live feed problem?
19sac65
posted on 11/1/15 at 06:59 PM Reply With Quote
Iif no power check the other end at the ecu for continuity
Could be a broken wire , usually where it meets the plug
posted on 11/1/15 at 07:25 PM Reply With Quote
Normally the coil pack and injectors share the same live feed, check both for 12v and check continuity between them.
