Author: Subject: Battery Cut-Off
daveb666
posted on 18/2/15 at 09:13 AM Reply With Quote
Battery Cut-Off
I'm fitting a battery cut-off to my car (more for security than safety) - therefore it's not a posh one with resistors etc, simply a cheap turn-key eBay special.
Does it matter which terminal I fit it to? The switch will be on my dashboard so I was favoring using the ground instead of the live but am interested to see if there is a right and wrong way to do it?
If I read Google then it's always the positive is used but that is in regards to racing regulations etc, which I'm not concerned with.
Ben_Copeland
posted on 18/2/15 at 09:19 AM Reply With Quote
Positive!!!
You can use it for isolating your battery properly then. Earth should work but do it properly Dave
Ben
Locost Map on Google Maps
Enter Your Details Here
steve m
posted on 18/2/15 at 09:23 AM Reply With Quote
I put mine on the Neg side, purely to keep all the power cables as short as possible
steve
whitestu
posted on 18/2/15 at 09:27 AM Reply With Quote
I would say the positive as well. That's what I did. I find it a really useful security feature in that it stops passers by switching the lights etc. on when the car is left somewhere unattended.
I bought ready made cables of the right length fairly cheaply.
Stu
MikeRJ
posted on 18/2/15 at 09:29 AM Reply With Quote
Doesn't really make any difference, the battery is isolated either way. Just don't disconnect it whilst the engine is running.
lsdweb
posted on 18/2/15 at 10:31 AM Reply With Quote
As Mike says, it makes no difference.
If you're having to extend cables to do it, then work out which you have to extend the least and use that.
There's no motorsport insistence on isolating the positive (the Cartek Battery Isolator disconnects the earth for example)
If there's no difference, I would use the negative / earth.
Wyn
britishtrident
posted on 18/2/15 at 11:11 AM Reply With Quote
If fitting for security you can get away with fitting it in the lead from the battery that feeds the fuse box rather than the main battery cable.
[/I]
daveb666
posted on 18/2/15 at 11:19 AM Reply With Quote
That sir, is a stirling idea!!
pewe
posted on 18/2/15 at 12:45 PM Reply With Quote
What Mike doesn't say is that you risk blowing the alternator etc. if you switch off whilst the engine's running.
For what it costs linky and the small amount of difficulty in fitting a resistor I'd fit one every time. They also do the switches.
Cheers, Pewe10
