Author: Subject: Electronic Speedo - how do they work?
Norfolkluegojnr
posted on 23/2/15 at 03:15 PM Reply With Quote
As above really. All other electrics are now working no the car expect the speedo.
its not a mechanical drive that i'm used too, so where to start with for fault finding? Is there some kind of standard diagram? the instruments appear to be labelled 'CA' - can post up pics if it helps.
Thanks in advance!
Sam_68
posted on 23/2/15 at 03:39 PM Reply With Quote
They can work in one of three ways, usually: by taking signals directly from the car's ECU, by means of a Hall Effect sensor attached to the gearbox cable connection, which 'counts' the rotations of what would be the speedo cable connection, or by counting magnetic pulses from magnets attached to the propshaft or a hub.
The latter is most common, and least reliable... it is quite sensitive to the position of the magnets and their clearance to the pickup, and can often become faulty due to build up of dirt on the sensor, the sensor position being disturbed, corrosion of the wiring connections to the sensor, or simple loss of a magnet (they're often epoxied in place, and simply drop off!).
'CA' sound like the CAi logo Caerbont Automotive Industries, who now also do the traditional 'Smiths' instruments. The 'i' of the logo is just a dot over the italicized serif of the 'A', so it's easy to misread!
Information here may be useful.
britishtrident
posted on 23/2/15 at 03:50 PM Reply With Quote
If you have a digital multimeter set it to a low range and you should be able to read the pulses from the sensor.
[/I]
Norfolkluegojnr
posted on 23/2/15 at 04:01 PM Reply With Quote
Thanks Sam,
Nail on the head - checked that website and the details match up, so I'm one step closer!
No ECU to speak of, so must be a magnet/pick up arrangement. I'll see what i can see with the car up on ramps - how big is the pick up?
Presume you can replace the magnets?
Thanks again.
Sam_68
posted on 23/2/15 at 04:06 PM Reply With Quote
Originally posted by NorfolkluegojnrI'll see what i can see with the car up on ramps - how big is the pick up?
Not very big - think in terms of something that looks a bit like an in-ear headphone. And yes, you can replace the magnets - they're usually just 'button' sized circular discs - not much different in size to a calculator/watch battery.
Norfolkluegojnr
posted on 23/2/15 at 04:32 PM Reply With Quote
Great thanks. Will have a look over the weekend.
LCB to the rescue as always!
