mk85
posted on 5/3/15 at 09:56 AM |
battery wiring
I have quite a few power supply that I need not my battery. What's the best way as I dont want to run lots of single cables to the positive
terminal
theduck
posted on 5/3/15 at 10:02 AM |
Fuse box?
mk85
posted on 5/3/15 at 10:31 AM |
What types are people using
ken555
posted on 5/3/15 at 11:28 AM |
This style
with the busbar common connection
britishtrident
posted on 5/3/15 at 12:46 PM |
The usual modern practice on tintops is to have a two leads coming from the battery feeding the fuse box and starter respectively. The mainly lead to
the fuse box goes through a high amp rated Maxi or Midi fuse then to the distribution fuse box(es).
Some but not all aftermarket fuse boxes have a bus bar built in.
The protection of Maxi or Midi fuse between the bush bar and the battery is a wise move.
On modern tintops the alternator power cable normally goes to a separate Maxi or Midi fuse.
You can get Midi fuses up to 150amp and Maxi fuses up to 500 amps
[Edited on 5/3/15 by britishtrident]
[/I]
britishtrident
posted on 5/3/15 at 12:54 PM |
quote: Originally posted by ken555
This style
That is a nice item I fitted blade & mini blade led fuses to my last tintop -- even just doing the essential fuses it was a chore to change
them over in both fuse boxes but it paid off on the only time a fuse blew.
[/I]
