Author: Subject: Blacktop Spark Plugs
Fandango
posted on 7/2/16 at 05:19 PM Reply With Quote
Hi all.
Just rounding up a few bits for the blacktop install.
Can anyone recommend grade of spark plugs required, for Blacktop, running R1 carbs, Nodiz ignition, will be track use only?
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
matt5964
posted on 7/2/16 at 06:26 PM Reply With Quote
I use denso itv16 iridium plugs if that helps
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
britishtrident
posted on 7/2/16 at 07:08 PM Reply With Quote
Iridium plugs definitely do maintain their gap even better than Platinum but double Platinum plugs are so resistant to gap erosion any that they are rated by some manufacturers that they are scheduled not to be changed for "the life of the vehicle".
The only caveat is to use the revised spark plug gap recommend in a Ford TSB of 1mm (0.040" previously it was 1.3mm. It was reduced because the higher gap created excessive spark voltage which caused a breakdown of the Ford coil pack insulation,
[Edited on 7/2/16 by britishtrident]
[/I]
