Author: Subject: speed sensor
Scubastu
posted on 19/12/04 at 10:52 AM Reply With Quote
speed sensor
I'm 95% of the way in fitting a Ford 2.0 DOHC EFI engine into my Midtec Spyder...(don't try this at home!...Modification city!)
The car uses a Renault gearbox so I cannot use the original Ford speed sensor.
I need to know if I can tap into the speedo speed sensor to give a signal to the ECU.
Will it give the correct number/type of pulses?
I have an Isspro electronic speedo. The sensor picks up from 10 magnets direct from a driveshaft.
Thanks in advance.
[Edited on 19/12/04 by Scubastu]
