Author: Subject: OEM Ford TPS Wiring
Ron Lang
posted on 5/3/17 at 05:14 PM Reply With Quote
OEM Ford TPS Wiring
Time to start giving back to the forum as well as asking questions!
For info, I believe the wiring for the OEM TPS for the throttle body used on the blacktop zetec with plenum setup is as follows:
Pin A: Ground (to ECU Pin 30)
Pin B: Signal (to ECU pin 8)
Pin C: 5v (to ECU pin 9)
Pin letters are shown on the side of the plug socket and ECU PIN numbers relate the emerald.
Hope this helps someone.
big_wasa
posted on 5/3/17 at 06:03 PM Reply With Quote
