Author: Subject: Bike Tachometer
max2503
posted on 12/8/17 at 09:02 PM Reply With Quote
Bike Tachometer
Has anyone fitted a motorcycle tachometer in their project? I just like the look of some of them, and it would be something different.
I'm running a 4age with an emerald ecu.
Many thanks
Nathsx
posted on 12/8/17 at 10:39 PM Reply With Quote
Its been done plenty with the bike engines unsure on using it on car engine though
MikeRJ
posted on 13/8/17 at 11:15 AM Reply With Quote
The majority of 4 cylinder bike tachometers would only get a fraction of the range used when hooked up to a car engine.
Angel Acevedo
posted on 14/8/17 at 06:36 PM Reply With Quote
It will depend on your Redline and the redline of the Donor motor on the Bike.
If you don´t mind it is irrelevant as long as the donor bike tach rerads higher than your engine can rev....
Which leads to what Mike RJ is talking about.
Nathsx
posted on 15/8/17 at 10:19 AM Reply With Quote
https://www.carbuildersolutions.com/uk/all-in-one-digital-dash-10k- black-face
This gives a similar idea but much less RPM, Fairly costly though
