ttalps2000
posted on 4/12/17 at 12:18 PM |
7" Headlamp Options
I need to get some new 7" mini style headlamps as the image break-point on one of them is quite blurry and failed iva on it!
Currently have Wipac Quadoptic units, but not very inclined to use them again!
Can anyone recommend other brands and places they have got them from with good results?
Mr Whippy
posted on 4/12/17 at 12:28 PM |
I used the crystal clear ones on my old Landy and am totally delighted with the result, look very modern, very clear, much brighter than before
(standard bulbs) and the beam pattern is super defined, one of the best I've seen even compared to modern cars. Highly recommend them.
btw these are so much better than the lamps you had as I had those too and replaced them for exactly the same reason. I think the problem is the glass
lens pattern is not very sharply moulded so the light is not focussed properly. With the mirror at the back it is very angular and sharply moulded in
the plastic and so much more precisely focused.
linky
[Edited on 4/12/17 by Mr Whippy]
ttalps2000
posted on 4/12/17 at 12:41 PM |
do they have sidelights?
Myke 2463
posted on 4/12/17 at 12:48 PM |
Another vote for crystal clear ones, available with or without side lights.
Be Lucky Mike.
ttalps2000
posted on 4/12/17 at 12:52 PM |
found them now! Will order some up
Thanks for the help!
gremlin1234
posted on 4/12/17 at 12:59 PM |
check that the bulb is seated correctly.
if getting new ones, I would get the ones with sidelights, even if you are not using them now, just keeps options open
ttalps2000
posted on 4/12/17 at 01:20 PM |
upon finding the units with side lights, they are "Europe and USA" which means British American, so need European type! Any helpers other
than Paddock Spares?
Bulb was seated correctly, even put a new bulb in. Made a tiny difference, but nothing significant.
The passenger side unit focus' as it should do!
theconrodkid
posted on 4/12/17 at 03:13 PM |
got mine from a place in brum that does landrover parts, sorry cant remember the name of the place but they were on fleabay
https://www.ebay.co.uk/itm/WIPAC-Crystal-Headlights-Half-Bowls-Defender-90-110-/360838606481
[Edited on 4/12/17 by theconrodkid]
who cares who wins
pass the pork pies
gremlin1234
posted on 4/12/17 at 03:51 PM |
minispares do some polycarbonate ones
http://www.minispares.com/product/Classic/Electrics/Lamps/S6072.aspx
no idea how good they are, but they claim they are E marked.
rimmerbrothers do a large range too
https://www.rimmerbros.co.uk/Item--i-GRID600207 (scroll page down for the list)
but indicate the crystal ones are no longer available ;-(
motorcycle_mayhem
posted on 4/12/17 at 07:38 PM |
Could you still use the sealed beam type for the IVA?
I still have Lucas sealed beam units on the SII LR, seem to work well (at least for the MoT). Obviates the need to concern yourself with getting the
right bulb position within the unit?
Mr Whippy
posted on 5/12/17 at 12:51 PM |
not sure what you mean tbh - Paddock do these -
Wipac Crystal Halogen Headlamp Conversion Kit (pair) including pilot light - left hand dip (UK and Australia)
Part Number: PM935
ttalps2000
posted on 5/12/17 at 09:19 PM |
i couldnt find them when looking, honest!
All ordered now, will let you know the results!
Thank you very much for your help! Much appreciated.
Matt
ttalps2000
posted on 14/12/17 at 09:46 PM |
Headlamps all fitted and have made a massive difference! Thank you for the help and suggestions!
Regan_M
posted on 5/1/18 at 10:00 PM |
Any pics of them fitted?
