Abe
posted on 26/7/19 at 06:08 PM |
Three wire speed sensor
Hi gang
Ok I’ve done something stupid... bought, made bracket, fitted magnets to drive shaft and installed a three wire speed sensor from Tiger racing...
looks lovely... except my ETB electronic speedo is an older two sensor wire input. Obviously I’m not getting a reading. Am I right in thinking I need
to replace the sensor with a two wire or can a three wire one be made to work? Three wire is negative positive and signal DC I believe whereas the two
wire I believe is AC. Hope that makes sense!
[Edited on 26/7/19 by Abe]
gremlin1234
posted on 26/7/19 at 06:16 PM |
quote: Originally posted by Abe
Hi gang
you might be able to make it work with various pull up/down resistors,
but some sensors pull down, other up, so quite likely not.
just get the right sensor, else you will always be doubting it.
Abe
posted on 26/7/19 at 06:51 PM |
I don’t know what pull up/down resistors are, so probably best I just get the correct sensor
Thanks for your reply
posted on 26/7/19 at 07:16 PM |
Etb wiring diagrams here
https://www.etbinstruments.com/index.php?route=product/category&path=17_85
Which model is yours.
A 2 wire speedo either will accept a pulse signal or have the wires grounded. If you are feeling brave, then connect to the speedo 2 wires, then
rapidly touch them together, if the pointer moves then we know how to drive it.
A metal comb is ideal for this test by dragging wire across the prongs will give rapid pulses.
Tbh sounds like electrickery is a mystery for you, how much is the correct sensor as you may damage a very expensive speedo.
Abe
posted on 26/7/19 at 07:50 PM |
Hi bud
Thanks for the reply....It’s not a ‘complete’ mystery as I’ve built a few wiring looms in my time, but I do have some gaps with stuff like this
It’s this speedometer... 80mm ETB Electronic Speedometer Mk2 (Rubber button on glass).
The original sensor was a two wire, picking up off a 15 hole disc off the prop shaft, smashed and mounted horribly, a new one is £80, the one I bought
from Tiger that I thought was compatible although mounted in a different location is £32. Was trying to save a few quid and make a tidy job of
mounting it too. Someone had already mounted a magnetic pick up, but that had been disconnected and was hanging off.
posted on 26/7/19 at 09:03 PM |
below is the relevant section; note the reed switch option.
either fit a reed switch - not ideal as they have limited lifetime and prone to bounce at high rpm - better make use of your 3 wire sender to drive a
transistor switch; example circuit using FET shown.
FET as a switch
Abe
posted on 26/7/19 at 09:36 PM |
Thank you so much that’s massively helpful
ianhurley20
posted on 4/8/19 at 10:07 PM |
I would be very interested in knowing if you got your speedo sorted - we have exactly the same non working set up at the moment!
Abe
posted on 4/8/19 at 10:39 PM |
Hi bud
I bought a cheap threaded M8 Reed sensor from eBay and have mounted that. After some speedo calibration i got some accurate results against my GPS.
That is until after 5 minutes, then the needle starts getting erratic and not at particularly high revs either. I may get a new speedo and use my
three wire hall speed sensor as the lcd display on my speedometer has also started glitching. Will play about tomorrow if I get time.
ianhurley20
posted on 5/8/19 at 07:50 AM |
Thanks for the update, our 3 wire sensor (Burton Power) will not light up the speedo at all at the moment, I'll post a solution if I find
one.
[Edited on 5/8/19 by ianhurley20]
