timB
posted on 12/9/20 at 02:32 PM |
cheap chinese tacho not working following accusparks points conversion
Hi, my points conversion went well, but now my tacho doesn't work. It was a £30 ebay job, so it's not the end of the world. I've got
the signal wire wired up to the -ve. Is there a way for me to bodge it somehow? thanks
tajgreidotu
posted on 12/9/20 at 02:50 PM |
Not sure if its this type, but my chinese speedo was not hard to wire following this image:
Don't trust wire colours but wire position instead, and good luck
[Edited on 12/9/20 by tajgreidotu]
timB
posted on 12/9/20 at 03:20 PM |
thanks for the reply, but I can't see that picture
I've got my signal wire to -ve of coil, how can I get that wrong?
perksy
posted on 14/9/20 at 09:39 AM |
Apart from double checking your connections you can't really
Don't suppose you have a timing light with a tacho inbuilt of similar? That would prove that everything was otherwise ok
