the_big_1
posted on 8/11/20 at 09:07 PM |
Blacktop Canister Valve Resistance?
Hi guys,
Looking to try have no active codes on my Blacktop and not having the canister valve, I am planning putting a resistor in. Does anyone know what the
valve resistance is or resistor size to fit? I don't have a valve to measure etc.
Cheers!!!
big_wasa
posted on 8/11/20 at 09:16 PM |
I’ve fitted a 2w 12v bulb on a little bracket under the dash.
the_big_1
posted on 8/11/20 at 09:21 PM |
Hi ya!!!!
Sounds like about 70 - 80 ohms.
Will see what I have around. Might have something, even a bulb too if needed.
Many thanks!!!!
big_wasa
posted on 8/11/20 at 09:31 PM |
I have had a meter on one but I can’t remember. You want a small enough current flow to cause no damage but enough so the ecu thinks the valve is
working.
big_wasa
posted on 8/11/20 at 09:32 PM |
Oh and As it’s looking for current flow you want a bulb not an led
the_big_1
posted on 8/11/20 at 09:33 PM |
Yep. 2W does sound about right for a solenoid.
If I had the original, I could have fitted that behind the dash lol
