Author: Subject: OT, Cd's sticking in player
John G
posted on 12/6/22 at 07:50 AM Reply With Quote
I have a Bosch radio / cd player in my van. The cd's are increasingly difficult to eject, any clues in a fix. The player is out of the van at the moment.
Any ideas on a fix?
David Jenkins
posted on 12/6/22 at 09:46 AM Reply With Quote
There will probably be some mechanism that carries the CD in and out - if you can access it, take a look to see if the pivots, slides and other gubbins is covered in crud. If so, try and get it out with q-tips, cocktail sticks, etc. (but be very careful!).
If you do get muck out, put on the tiniest bit of lubricant, using a cocktail stick or similar. You want the merest trace of lube on the contact surfaces.
But, TBH, your chances of success are slim...
Mr Whippy
posted on 12/6/22 at 03:37 PM Reply With Quote
Buy a Bluetooth one of gumtree, still using CDs in 2022...
John G
posted on 12/6/22 at 03:53 PM Reply With Quote
cd
The advantage of my original is that the reversing sensors go through the radio, very useful in a van!
posted on 12/6/22 at 04:01 PM Reply With Quote
Spot on, if you can get the thing open it'll be a mechanism clogged with crud. Clean very carefully and delicately lube. Hard to do, but best chance of restoring function.
Failing that it's a replacement called for. Like most things getting the rights make, model, year etc may be difficult.
Best of luck.
cliftyhanger
posted on 13/6/22 at 08:15 AM Reply With Quote
Get one of these thingies, dump the cd's
https://cdn.media.halfords.com/i/washford/756621?w=1480&h=1110&qlt=default&fmt=auto&v=1
[Edited on 13/6/22 by cliftyhanger]
posted on 13/6/22 at 02:44 PM Reply With Quote
It's true there's something to be said for connecting your mobile to the vehicle via Bluetooth. Allows streaming of music from the phone, ideal from Spotify and the like. Also handy for hands-free calls too - could be useful in a work van.
Do the reversing sensors still work even though the CDs are troublesome ejecting?
