reck
| posted on 6/12/05 at 07:32 PM |
running a loom
Hi all
can you help, i know you should not run the electric loom along side fuel lines but how close is exceptable????I want a parallel run about 120mm apart
along the transmision tunnel. Any comments.
phoenix70
| posted on 6/12/05 at 07:54 PM |
I don't think there is anything specific in the SVA manual in this regards, but I can't seen any problem with that spacing. In fact I run
both my fuel pipe and electrics down one side of the tunnel with about 6cm between them..... although my car hasn't been through the SVA yet.
Later
Scott
BKLOCO
| posted on 6/12/05 at 08:05 PM |
All I could find in the SVA bible was that they should not share the same clips.
However most people recomend running them on opposite sides of the tranny tunnel.
silex
| posted on 7/12/05 at 05:59 AM |
And it would make safety sense to run the harness above the fuel lines (in case of leaks).
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
reck
posted on 8/12/05 at 06:22 PM |
Wiring and fuel lines
Thanks for the words of wisdom, I'll feel happier now you dont think im doing anything to daft.
