RobC
| posted on 6/12/05 at 10:25 PM |
major problems with wiring & digidash
Not the best when it comes to electrics, but... before I started messing tonight my digidash worked when you turned the ignition key. Now it
doesn't it still works when I mess about with the wiring I did do... but not sure what I have done to mess things up. After taking apart all the
wiring I had done and removed it... Digidash still not working? Any ideas, as I am feeling rather lost for ideas
Many thanks
Digidash is mk1 if this helps any
[Edited on 6/12/05 by RobC]
k33ts
| posted on 6/12/05 at 10:36 PM |
not fimiliar wi digi dash but im sure youll have two feeds 1 permanent 1 ign fed check these for power 1st if still no go check and maybe redo earth
to different place, straight to battery 1st to see if thats the prob.
RobC
| posted on 6/12/05 at 10:41 PM |
will try again tomorrow. kind of had enough with it tonight you kind of know things are going down hill when your talking to yourself in the
garage
Rob
shortie
| posted on 7/12/05 at 09:13 AM |
Rob,
You may have blown the inline fuse in the Digidash live feed wire so check this first.
I have a wiring diagram here http://www.dewweb.co.uk/indyblade/images/Indyblade_wiring_v17.pdf that shows how I connected my DD1, not sure
what engine you have but at least it may help.
Rich.
jos
| posted on 7/12/05 at 10:16 AM |
The thing Ive learnt when trying to resolve electrical gremlins is ALWAYS CHECK THE EARTH FIRST
RobC
| posted on 7/12/05 at 07:59 PM |
Don't panic Mr Mainwaring!!!!!!!!
All sorted just a blown fuse thankfully. Although I have learnt my lesson and will be calling in the help of people who know what they are doing
Just need to get the hazard and indicators done, and I would be guessing how to wire those suckers up, so best to be save.
Cheers for the help last night
Rob
