mkblade
| posted on 12/3/06 at 03:27 PM |
hazard relay
can any one help ??
im changing back to the 3 pin flasher relay.
ive disconnected the relay i had on there, it was for led type lights (flashers)
im now left with 3 wires
white/black tracer
brown/yellow tracer
brown
its a premier wiring loom i need to know which wire goes on which terminal
terminals on the 3 pin relay are 49,49a,31
thanks
simon
dave1888
| posted on 12/3/06 at 03:34 PM |
49 is the supply voltage from battery
49A is the power to ind switch
31 is your earth
not sure about which wire goes where though.
Deckman001
| posted on 12/3/06 at 03:47 PM |
Simon, I've got the premier wiring Notes, but there isn't any pin numbers on them to show what goes where, and I don't have my car
here at the house, your welcome to borrow the notes though if it helps ???
Jason
RazMan
| posted on 12/3/06 at 04:41 PM |
Its probably safe to say that the brown is an earth (check it with a continuity tester first though) The other two will be power & load which you
can also test with a circuit tester.
Hope that helps
Raz
mkblade
| posted on 13/3/06 at 10:38 AM |
cheers guys
ive spoken to alan at premier hopefully got it sorted .
it doesnt say in the notes as orginally it was prewired and i got the block off to fit this led type relay.
thanks si
