Author: Subject: Any Thatcham installers here?
nitram38
posted on 13/3/06 at 07:26 PM Reply With Quote
I have had an offer of a low insurance deal if I have a Thatcham immobiliser fitted.
I am an Electrician and I wired my car in the correct lucas colours and everything works as it should.
I know it is cheeky but I can buy and fit a Thatcham alarm from Feebay but I need the approval certificate done correctly for my insurance.
Will any fitter do or must they be on an approved list?
Is there anyone here who are willing to either certificate it or fit the unit?
rayward
posted on 13/3/06 at 08:47 PM Reply With Quote
If you fit the unit yourself, and take the car to an approved installer, they can inspect the installation, and issue a certificate if it complies.
the last time i had one done, it cost about £30.
Ray
nitram38
posted on 13/3/06 at 09:29 PM Reply With Quote
Thanks Ray
RazMan
posted on 13/3/06 at 10:25 PM Reply With Quote
Out of interest, what is involved in fitting a Thatcham alarm? It might be a good idea for me to install as I'm finishing off my wiring at the moment.
Raz
k33ts
posted on 13/3/06 at 11:16 PM Reply With Quote
nitram can you show me what type of cat2 your looking at.
theres some crap on ebay
i might be able todo something for you
razman
are you wanting todo cat1(full alarm) or cat2(immobiliser)
[Edited on 13/3/06 by k33ts]
nitram38
posted on 14/3/06 at 10:35 AM Reply With Quote
k33ts
I have seen some Gemini, sterling or toad immobilisers from £35-45.
As long as it is thatcham, my insurance will accept it.
I can install any immobiliser/alarm, but it is the certificate that I need for the insurance company.
Three I am looking at:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=8045024756&ssPageName=STRK:MEWA:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=8046437181&ssPageName=STRK:MEWA:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=8044648148&ssPageName=STRK:MEWA:IT
Regards Nitram
[Edited on 14/3/06 by nitram38]
nitram38
posted on 29/3/06 at 11:27 PM Reply With Quote
Just fitted mine
It requires disabling two circuits. I used the feed to my engine relays and my starter motor.
All of the cables are black with coloured markers. These are removed during fitting.
I opened the loom up and located my ign feed to my relays and the starter signal wire. I cut back about a foot so that they cannot be joined or hot wired. The control box wiring was linked to these two circuits and I soldered/heatshrinked them.
You will need to locate the led and an induction loop (usually around your ign key under the panel) You will need to connect a perm live, ign live and 2 seperate earth points.
Afterwards I re-wrapped the loom and spiral wrapped it. The idea is to make everything blend into the loom to make it difficult to hotwire.
You would not be able to find mine in a hurry !
[Edited on 29/3/06 by nitram38]
RazMan
posted on 5/4/06 at 09:42 PM Reply With Quote
Originally posted by k33ts
razman
A full alarm system is pretty useless IMHO as nobody seems to take the slightest notice of them anyway now days. An immobilisor would be my choice, but with a remote control for arming & disarming - maybe even remote starting too
Any recommendations?
[Edited on 5-4-06 by RazMan]
Raz
nitram38
posted on 5/4/06 at 10:17 PM Reply With Quote
razman
Hope you have deep pockets. Cat 1 thatcham with remote start are pretty expensive. The only way you can do this is buy an alarm and turn the sounder off if you don't like the noise.
Ferrino
posted on 9/4/06 at 04:27 AM Reply With Quote
Hi Nitram
Sounds like the same setup as my Toad Powerkey immobiliser which I am about to wire up.
What have you done with the yellow wire, which I think gets connected to the door switch in a tintop? Do you just leave this disconnected?
I guess the wire coming from the ignition switch tells it to start searching for the keyfob.
nitram38
posted on 9/4/06 at 05:09 AM Reply With Quote
Mine is a toad too. Just rebranded as excel.
I left the yellow wire disconnected.
Ferrino
posted on 9/4/06 at 04:51 PM Reply With Quote
cool, cheers!
