Author: Subject: ZX12-r vehicle down sensor
athoirs
posted on 28/3/06 at 03:17 PM Reply With Quote
If anyone can help..
My engine did not come with a vehicle down sensor - not a problem - but ..
Three wires into it +12v , ground and the output which goes straight to the ecu... so does the ecu need 12v, ground, another voltage to make it think its connected??
If no-one knows can some kind chap stick a voltmeter on the output for me...TA
Hellfire
posted on 28/3/06 at 04:05 PM Reply With Quote
So - if you're upside down what will stop your engine?
Seriously - if you're stuck I could help our bike down sensor is located near the battery which is low down in the rad/engine void so difficult to access. What wire feeds are there in particular the ECU - I could measure that when fired up possibly Thursday evening.
[Edited on 28-3-06 by Hellfire]
Smartripper
posted on 28/3/06 at 04:54 PM Reply With Quote
Hello,
In the service manual, it said.
the yellow and green wire needs between 0,4 and 1,4 volt then the engine will run.
But try too get a sensor because when good placed it also cut the feul in an accident.
Daniel
yorkshire-engines
posted on 28/3/06 at 05:55 PM Reply With Quote
tip sensor
hi Iv got one if you need it you can bypass but its better to run one
give me a ring 0796011585
cheers malc
athoirs
posted on 28/3/06 at 08:38 PM Reply With Quote
Thanks for the reply guys...
Malc (Top Bloke) is going to send me up one which is probably the best thing if it gives out a variable voltage..
