Author: Subject: car cut out a low revs
ditchlewis
posted on 27/6/06 at 07:44 PM Reply With Quote
i know that my car has a bad earth, but would it cut out at low revs when it is running?
bump started the car and as long as i kept the revs up the engine runs, but take your foot off the accelerator and the engine dies?
is this an electrical problem or is it a mixture of problems?
Ditch
big_wasa
posted on 27/6/06 at 07:45 PM Reply With Quote
sounds like an air leake if it was running ok ?
posted on 27/6/06 at 08:03 PM Reply With Quote
in the short term you could just wind the throttle cable up a bit, so it idles higher. Could be a multitude of problems. How well tuned is your engine (not how powerful, but has it been on a rolling road etc?) Id start with checking emissions and voltages.
gary gsx
Why bump start it is battery flat?
andyharding
posted on 27/6/06 at 08:13 PM Reply With Quote
If it has one you did remember to run an ignition live to the anti-run-on valve on the carb didn't you?
Are you a Mac user or a retard?
ditchlewis
posted on 28/6/06 at 07:05 AM Reply With Quote
had to bump start it because even when attached to another car the engine barely turned over.
what anti run on valve????
ditch
posted on 28/6/06 at 06:26 PM Reply With Quote
What type of engine/carbs/injection are you using?, may help with diagnosis
ditchlewis
posted on 29/6/06 at 07:09 AM Reply With Quote
i'm running a 2.1 pinto with twin dellorto 45's.
suppose i could chesk the live side of the battery circuit.
ditch
