Author: Subject: Seedo Magnets Dimple Orientation
Avoneer
posted on 19/7/06 at 09:46 AM Reply With Quote
Dimple against the meal or facing out into air?
Pat...
posted on 19/7/06 at 09:57 AM Reply With Quote
If you're using ETB magnets then the dimple definitely faces out (towards the air).
Stick em on tight mind!
Krismc
posted on 19/7/06 at 11:05 AM Reply With Quote
yea dimple out with MY ETB guages
donut
posted on 19/7/06 at 01:33 PM Reply With Quote
same here
Avoneer
posted on 19/7/06 at 10:52 PM Reply With Quote
Cheers.
So inverted niples facing out it is!
After trying all sorts on the Avon, I think there is only one solution to fixing them on:
Blob of Sikaflex and then gaffa tape.
Tried glassing them on, araldite and a few other methods and they all failed on the Avon.
Gaffa tape on it's own was the only thing that eventually worked.
Don't think the Sika will ever let go though, but the gaffa on top should do the job.
Pat...
Krismc
posted on 20/7/06 at 08:26 AM Reply With Quote
i used arildite and seems to work fine
numnuts
posted on 20/7/06 at 11:45 AM Reply With Quote
Hi guys Ithink this may be incorrect as the instuction from my digi dash states :: The dimples must face the propshaft and not outwards .. not sure if correct but thats what my instruction states !!. hope this helps
Avoneer
posted on 20/7/06 at 10:58 PM Reply With Quote
I couldn't find that in the instructions - where does it say that?
Not questioning you, just curious as want to get it right.
Pat...
Avoneer
posted on 20/7/06 at 11:31 PM Reply With Quote
Found it on the website:
"The magnets have small dots on one face. These denote the magnet North pole. The magnet
MUST be mounted with the dot facing down."
Pat...
[Edited on 20/7/06 by Avoneer]
numnuts
posted on 22/7/06 at 04:21 PM Reply With Quote
I am now sure as my speedo passed sva yeaterday perfectly at 30 50 and 70
Krismc
posted on 23/7/06 at 09:36 AM Reply With Quote
well mine works and im sure thats the way i put them!?! might me different for different applications
DarrenW
posted on 24/7/06 at 03:43 PM Reply With Quote
Dimple in on mine. Araldite was also crap. Softened after a while and magnet detached itself. i then fixed with Wurth superglue after getting down to bright metal and using Wurth high power cleaner. Then used JB weld for extra stiction. Been Ok since.
