davrus
posted on 23/7/06 at 03:00 PM |
alternator wiring
Greeting
I have a 3 pin alternator , it has 2 large spade terminals and 1 small spade terminal , can any one tell me which one goes where .
many thanks
Davrus
zilspeed
posted on 23/7/06 at 03:09 PM |
Make and model of alternator ?
Some need a sensor wire, some don't.
jollygreengiant
posted on 23/7/06 at 05:34 PM |
IIRC the two large are for positive feeds, use either or both and the small one would be for alternator warning lamp.
If you go to a good auto electrics supplier you should be able to buy a new din plug fitting kit with new terminals to fit. If its from the old Lucas
ACR series alternator.
lotustwincam
posted on 23/7/06 at 06:30 PM |
Jollygreengiant is correct.
Two large connections are the same and are the positive feed back to the battery.
Small connector is from/to ignition light.
When ign is swithced on, current flows from battery thro ign light to alternator, to energise stator coils - creating a magnet. Once engine is
started, alternator supplies its own current for the stator coils and thereby feeds 12v back out the small terminal to extinguish ign light. (12v on
both sides of the bulb).
Drew
posted on 24/7/06 at 01:37 PM |
lotustwincam is right.
the two big blades (6.8mm) are commoned - usually you need to use one with small - 60 amp or less output alternaotrs; for bigger ones, like land
rovers, you'd wire both in parallel to allow fatter wires to handle the larger currents.
smaller one is 4.7 mm. VWP sell the connector or use 2 or 3 spades.
davrus
posted on 25/7/06 at 09:47 PM |
cool , thanks for help , works like a dream
Thanks again
