richyo
posted on 6/10/06 at 12:12 PM |
Oil Pressure Sender
Might be in the wrong section but here goes.
I'm fitting an oil pressure gauge and want to know if I attach the oil warning light wire (from the light on the dash) to the same connector
that the oil pressure wire attaches to ?
TIA
Richyo
tks
posted on 6/10/06 at 12:25 PM |
No!
An sensor is one thing..
in fact it can measure a RANGE from pressures..sow the signal it gives is relative to the measured value.
A Low pressure SWITCH is just a switch wich provide ground to a bulb.
It has only one setpoint! and below that value it switches on.
Sow the answer is no, don't connect the bulb to the sensor.
Tks
The above comments are always meant to be from the above persons perspective.
