Author: Subject: Fuel guage sender unit resistance
izzy spyder
posted on 31/10/06 at 07:25 PM Reply With Quote
Ive got a set of honda blackbird clock fitted to my car and i can't find a sender unit to fit my tank which is 4 times larger then the bike tank with the same resistance 4 - 10 ohms full 81 - 91 ohms empty any ideas around this one?
DIY Si
posted on 31/10/06 at 08:03 PM Reply With Quote
couldn't you just extend the arm on the bird sender?
Sun Tzu, The Art of War
posted on 1/11/06 at 07:57 AM Reply With Quote
that is exactly what you have with series land rover senders - a two piece arm and some very small clips that look like staples.
You bend the arm to shape to give the right readings and use the clips - belt and braces I used plumbing solder - I can send you a strip if you need that - and dcone well away from the petrol tank.
A piece of wire coat hanger or thick gardening wire could be used.
[Edited on 1/11/06 by 02GF74]
