mike smith1
posted on 19/11/06 at 01:41 PM |
Speedo Healer Calibration Help
Having trouble calibrating the speedo healer, I have a 1997 Fireblade but we are using the 1998 speedo sensor (that is normally mounted in the
gearbox) externally it is picking up a signal from 2 magnets mounted on the prop adaptor. When you put the speedo healer into test mode it moves the
needle on the speedo to 15mph and when you rotate the prop so that the magnets pass the sensor the led lights up (signal being recieved). When you
reset the speedo healer and put it into transparent mode to calculate the total error, the speedo does not read at all, when the wheels are jacked up
on axel stands, or on the road.
Would also be grateful if anyone could give there calibration details for a 97 or 98 blade with 195/55/R15 Tyres and a 3.92 Non LSD Diff.
Hope you can understand the waffle above, all help appreciated.
Mike
esn163
posted on 19/11/06 at 03:00 PM |
Hi Mike
this might help
see post here
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
mike smith1
posted on 19/11/06 at 03:07 PM |
quote: Originally posted by esn163
Hi Mike
this might help
see post here
Ed
I was planning on using the spreadsheet method as you did Ed but i cannot work out the indicated speed as there is none when the speedo healer is in
transparent mode.
Its complicated
Mike
mike smith1
posted on 20/11/06 at 11:48 AM |
Have emailed Speedo Healer Technical Support. However i would be grateful if anyone on here can help to.
I just wanna get it done
Mike
mike smith1
posted on 20/11/06 at 03:05 PM |
Reply from Speedo Healer Sopport:
HealTech Electronics <info@healtech-electronics.com> wrote:
Hi Mike,
The problem is that the input signal is so slow that it will not drive
the
speedo.
You may notice a little speedo movement when you spin the wheel in 6th
at
full throttle.
You need an "SH-C8" , this is a unit with extended calibration range.
It can be ordered through the following page:
http://www.healtech-electronics.com/en/order.htm
Should you have any further questions, please feel free to contact us
again.
Kind Regards,
/Norbert
So looks like i gotta buy another unit, unless someone on here can help!!
Mike
esn163
posted on 20/11/06 at 08:15 PM |
Hi Mike
Just a thought
if you've got to speed up the signals, couldn't you just use more magnets spread equally around the prop rather than buying another unit
to speed up the rate?
see thread
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
mike smith1
posted on 21/11/06 at 08:55 AM |
I think its definatly worth a try before i fork out for another unit
Mike
DIY Si
posted on 21/11/06 at 09:15 AM |
That's what I'd suggest. I think there's 4 magnets/pickups in the bike box, quite possibly more though, so to save a lot of money
just add more magnets. If that doesn't work, just add some more until it works!
Sun Tzu, The Art of War
Hellfire
posted on 21/11/06 at 12:36 PM |
Or just use a 1997 speedo sensor instead of a 1998
Phil
mike smith1
posted on 21/11/06 at 05:01 PM |
Phil
I would but i wanted the newer style blade clocks so i need to use the newer sensor, it has been done before by others, i'll sort it!
Mike
