INDY BIRD
posted on 19/11/06 at 02:35 PM |
zx12r wiring/immobilizer HELP
Hi guys
need some help.
its a 2001 zx12r engine has been running finr but now it wont start i get ignition but the fuel pump is not kicking in the clocks needles zero but its
like the immoblizer has kicked in.
any ideas where to start to look??
its done this before and we fiddled with the bikes ignition barrel and them it seemed to work,
and before that it done it once we left it for a couple of days and then it just fired sttraight up. very confusing.
any ideas gratefully received,
Sean
yorkshire-engines
posted on 19/11/06 at 07:55 PM |
Hi The zx12 works on a 100 ohm resistor built in the back of the ign lock strip thr lock and clean the contacts itll work ok after that
cheers malc
INDY BIRD
posted on 19/11/06 at 08:10 PM |
cheers ill give it a try.
Sean
