joscorstjens
posted on 20/5/07 at 10:44 PM |
how to controll IAC valve on Pinto
Hi, I'm trying to figure out how the IAC valve on the Pinto is controlled. Is it reset at every startup? Is the valve driven by a stepping motor
or just pulse width controlled? Does anybody have more info on the electric part of the IAC?
tia
jollygreengiant
posted on 21/5/07 at 02:25 AM |
Just a solenoid opened by a pulse and closed by switching off current/voltage flow. Switched off possition is closed so automatic reset if you want
to call it this.
