Author: Subject: suck or blow
iceman26
posted on 29/7/07 at 08:12 PM Reply With Quote
suck or blow
ref fan
now i have your attention
do i need a fan that pushes or pulls it is going to be mounted in the nose cone
thanks
designer
posted on 29/7/07 at 08:27 PM Reply With Quote
Is the fan electric?
In front or behind radiator?
jos
posted on 29/7/07 at 08:50 PM Reply With Quote
it needs to flow the air through the radiator in the opposite direction to travel
it needs to flow air from the nose cone to the boot
so if you mount the fan infront of the rad it needs to blow
i fyou mount it behind it needs to suck
check sucking or blowing with a piece of tissue or light weight cloth
robertst
posted on 29/7/07 at 08:52 PM Reply With Quote
and it doent really matter which you choose. their performance (cooling-wise) is more or less the same
Tom
