blakep82
posted on 16/10/07 at 06:49 PM |
who's got one of these Vapor thingys?
Seems a good deal, don't much like the look of it though, and i've already got holes cut in a proper carbon dash (2nd hand, from one of
the racing trucks)
am i missing something? is there any expensive stuff it needs before it'll work?
I'd rather have proper round gauges, but this does the job of many, and cheaper than 1 speedo...
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=412_1808&products_id=13584
________________________
russbost
posted on 16/10/07 at 07:07 PM |
Think it's a good unit & brilliant price, only shortcoming I'm aware of is that it has no fuel gauge. There is a surround for it for
about £25 which has all the warning lights in it.
blakep82
posted on 16/10/07 at 07:13 PM |
yeah, i'm thinking about it really only for the speedo... my carbon dash already has 5 warning light holes, 2x52mm, & 1x80mm holes cut, plus
a few for switches etc.
is it illuminated? it has to be for SVA doesn't it? says its E marked though...
speedyxjs
posted on 16/10/07 at 07:28 PM |
They look good but my only problem is that my engine for examole will only rev to 6500 so it might look a bit strange when the revs on the vapor go up
to 12000
INDY BIRD
posted on 16/10/07 at 07:45 PM |
Hi i got one,
It has a perm 12v supply from battery which goes off after 20mins i think that lights it up blue, or you can just run it with the self contained
battery in the unit, which then has a very dim back light,
Using also just for speedo only but has a rev counter abd shift light incoparated and temp guage,
donut
posted on 16/10/07 at 08:36 PM |
How do you set up the correct Miles Per Hour and how is it adjusted?
macdave69
posted on 16/10/07 at 09:44 PM |
Mine is a little troublesome, the speedo is accurate enough for the SVA but the rev counter can't keep up with demand and the temperature gauge
needs resetting every trip. I'm not sure I would buy another
