Author: Subject: fuel pump connection- is this ok?
les
posted on 12/3/08 at 09:38 PM Reply With Quote
Hi all,
I have to fit a second fuel pump with a swirl pot I have fitted, the advice seems to be to run a new positive wire rather than run it from the first pumps connections,
can I run a wire direct from the battery, with its own switch?
will that cause any problems- battery discharging etc?
les
RazMan
posted on 12/3/08 at 11:24 PM Reply With Quote
Agreed, it would make more sense to common the pumps together and run them from one fuse - easy to fault find too.
Raz
les
posted on 13/3/08 at 09:13 AM Reply With Quote
thanks guys,
sounds like the answer
les
