Author: Subject: headlamp flasher
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 21/4/08 at 10:00 AM Reply With Quote
headlamp flasher
My headlamp flasher isn't working, checked the fuses they're ok, could there be a relay somewhere i've missed ? I'm using Ford sierra column and switches
any help gratefuly received as electrics aren't my strong point
ta
graememk
posted on 21/4/08 at 10:08 AM Reply With Quote
i havent got one, its not needed for sva.
DaveFJ
posted on 21/4/08 at 10:42 AM Reply With Quote
to get the flasher working I believe you need to add another +12v input to a pin on the sierra stalk...
I believe it is the top pin of the set of 4 for the headlights - but I may be wrong....
HTH
Dave
paulmw
posted on 21/4/08 at 11:55 AM Reply With Quote
We had problems with the Sierra relays. Out of about 5 only one worked. Make sure you get a new relay (CBS do them for around £5)
Paul
Schrodinger
posted on 21/4/08 at 06:36 PM Reply With Quote
IIRC pin15 needs a supply from the right hand switches
Keith
Aviemore
hearbear
posted on 21/4/08 at 08:10 PM Reply With Quote
Hi Schrodinger
What was wrong with Scotland?????
3.9Ltr SSC Stylus should be fun
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
posted on 22/4/08 at 01:48 PM Reply With Quote
Thanks all, will check those out.
Steve Lovelock
posted on 22/4/08 at 04:58 PM Reply With Quote
There exists somewhere on this site a link to a full Vicki Green (Robin Hood) loom diagram. This has a breakdown of the Sierra stalk connections. I used this on my loom and agree that there is a pin that needs a power supply to power the flasher, sorry don't remember which one. I didn't need a relay, it does depend on what model of switch system you have. Hope this helps.
