Author: Subject: Does the Koso RX1N have an oil pressure sensor?
Gergely
posted on 28/5/08 at 07:56 AM Reply With Quote
Hi, do I need a seperate oil pressure gauge for the car do you think, or the Koso will have a pressure sensor and warning light that should be enough?
I really only need a pressure light or gauge to make sure I don't damage the engine by accident...
Thanks for your help!
Gergely
Adam
posted on 28/5/08 at 08:28 AM Reply With Quote
With my Koso i only got temperature sensors...ie water and oil. No pressure sensor's.
HTH
Adam
theconrodkid
posted on 28/5/08 at 08:54 AM Reply With Quote
got an oil light on mine,its a bit small tho
who cares who wins
pass the pork pies
Gergely
posted on 28/5/08 at 08:58 AM Reply With Quote
Yes, I know there is a light, but I don't see any sensors either. Where does it take the reading from then?
Adam
posted on 28/5/08 at 09:12 AM Reply With Quote
thats just an oil level warning as far as i know. Basically connects to the engines standard warning sensor.
Adam
rgrs
posted on 28/5/08 at 10:49 AM Reply With Quote
The oil pressure sensor is an option on the koso dash, you can buy the sensor as an addition but the on the dash you have to switch between displaying the water temp or oil temp. The tiny oil light on the dash is normally connected to the engines existing low oil pressure switch, however its so small you might not see it until its too late.
Regards Roger
Gergely
posted on 29/5/08 at 08:47 AM Reply With Quote
OK, thanks guys. It seems a proper pressure gauge is requred then...
