carnut1100
posted on 12/1/04 at 02:18 PM |
MX5 electrics to Locost
A friend and I are building a MX5 powered Locost. We will be getting the engine with the computer wiring.
Do I need the instruments as well?
Should I get a half cut?
Where can I get a wiring diagram?
mackie
posted on 12/1/04 at 03:38 PM |
I'd recommend getting the clocks if you can. Half cut?
Haynes manual will have wiring diagrams.
GO
posted on 12/1/04 at 03:48 PM |
Half cut - not quite drunk enough to fall over with no encouragement.
IIRC a half cut is basically everything forward of the firewall. I always imagined they actually cut the car in half and you got the lot, not sure if
this is the case though - might caused problems with the loom/ecu! I think its everything for the engine to run apart from fuel tank. Not sure if you
get clocks etc with it.
Bob C
posted on 13/1/04 at 12:10 PM |
mx5 electrics
Which motor/ecu?
On the early 1.6 (which I know a bit about) the instrumentation is all traditional with seperate transducers for the dash & ecu so you could mix
& match if you want. If you use a different tacho watch out for it reading half way because the 5 uses a wasted spark no-distributor system,
tacho just connects to one LT.
Oh and early 1.6s had a crank pulley problem which appeared over time - if it's early 90s & the pulley has 4 bosses on watch out, if
it's wobbly you'r living on borrowed time! Otherwise it's built like a brick outhouse & you can buy a turbo from FM in the
states to take it up to 270+ horses (genuine - I've had a do in one...) These systems ditch the big air flap in favour of a MAP sensor.
Mazda dealers can be funny about supplying parts for an eunos roadster - they want to get the jap parts at enormous expense/delay. Differences are
minor - different winfscreen glass or dash bulbs, important stuff (eg the ECU itself) is identical around the world, even though the dealers will
swear blind to the contrary.
JAG
posted on 13/1/04 at 04:06 PM |
Carnut - I have been doing exactly the same thing for the last 18 months. I have found this engine/ECU/fuel injection diagram;
http://www.cmr.uq.edu.au/~rotor/the_shed/jpg/b6-ecu.png
It's the same as the engine I have from a 1993 1.6 Mk1 Eunos (Jap import). Email or U2U if you want anymore info etc....
Justin
Damo
posted on 13/1/04 at 05:07 PM |
Carnut - Have you tried asking some of the members of the mx5oc forum? (www.mx5oc.co.uk) They are usually a pretty helpfull bunch, if not then there
is an email digest which you could try as I know there are a lot of Mx5 drivers out there that have this sort of information already on their
computers. I have a manual at home for the mk1 and will check that tonight to see if there are any suitable diagrams that may be of interest to
you.
JAG - Are you using the rest of the running gear from the MX5 or just the engine and ECU? I'd be quite interested to hear how you are getting on
with that as the MX% is one of my possible choices for running in the locost i am planning at the moment.
JAG
posted on 13/1/04 at 07:22 PM |
MX5 parts are the engine/fuel injection/ecu/gearbox. The rest is standard Locost fair, Escort rear axle, Cortina uprights etc...
Check out the photo archive for some piccys.
Justin
carnut1100
posted on 14/1/04 at 07:24 AM |
A half cut is just the front half of the car cut across the front floorpans.
Here in Australia it is extremely difficult to import a car which was available here in a similar form. Basically the only way is as a private import,
and to do that it must have been registered in your name for a while. Also whole vehicles are not allowed to be imported for wrecking so they are cut
in half and imported that way.
A Locost in Australia comes under new car legislation, so we have to use a current motor (basically it must pass EU2 emmisions ) so we are using a
current model 1.8 motor (BP I think).
We are using Cortina axle, uprights etc and Escort rack.
We probably won't be gitting the dash, as we re finding it hard to locate a half cut at the moment, and it would be dearer than a bare motor and
box anyway.
Thanks for the offer of info and help, and I will probably take you up on that soon. At the moment we have a tacked welded chassis and no motor so it
might be a little while.
Thanks olso for the links, I will follow them up when I have a bit more time ( I am only temporarily on the computer at the moment).
