Author: Subject: Dip beam stopped working PART 2
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 23/4/09 at 11:22 PM Reply With Quote
Thanks for the previous replies, i thought i would start a new thread to continue on:
I haven't had a chance to get a couple of new bulbs yet. Hopefully at the w/e.
Meantime I did get a new relay and the dipped worked fine until I switched the main beam on, then neither the dipped or main beams worked?! Side lights still work throughout.
So next job is to replace the bulbs as you have suggested but would you know if I will I need to get new relays as well ? I.E does the fact that it buzzes mean it is knackered ? If it does I could get through a few before I sort this prob out! Or I take it to someone who knows a bit more about electrics than me...
Any guidance/help much appreciated
iscmatt
richardlee237
posted on 24/4/09 at 05:43 AM Reply With Quote
A buzzing relay can be caused by several things
1)The voltage on the coil being too low due to poor connection or incorrect circuit, possibly due to coils being in series.
2) It is possible to connect the coil through its own contacts so that every time the coil is switched on, its contact switches it off, the contact re-opens and the coil re-energises, and so on. The relay acts exactly like a electric buzzer.
Very difficult to offer better suggestions without a wiring diagram, I'm afraid
Richard
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
mad4x4
posted on 24/4/09 at 06:45 AM Reply With Quote
Had problems lately with Indicator relay buzzing
Eath was the prblem, I had the scuttle off to check some wiring and the bit of ally in the scuttle was not touching the chassis. THis caused wired things like indicator to come on with wipers and buzzing relays.
Check the earthing points of the lights and the relays and the column.
Scot's do it better in Kilts.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 24/4/09 at 09:57 AM Reply With Quote
hi thanks for your replies and i will look further into all your suggestions.
I thought i should just make it clear that these lights have been working fine for 2 years so it is not a case of which wire is wrong or relay being wrong.
Using the replies i'm thinking that a connection must be poor or something is up with the earth.
Anymore suggestions on the buzzing relay fiasco would be great!!
