Author: Subject: Ford coilpack, what type do i have and what leads do i need.
dhutch
posted on 17/5/09 at 08:11 PM Reply With Quote
I have this type of coil pack
Rather than this type which seam to be more common.
Apprently one is more hard to find plug leads for, but i dont know which!
I beleave these plugs leads will fit the second of the two shown above, and are for a CVH. But what do i need for the coilpack i have.
- I presume it cant just use the leads the go to my (bosch) distributor at present, but am stuggling to know what would fit. Or do i have the one that you cant find leads for!!
Daniel
dhutch
posted on 17/5/09 at 08:12 PM Reply With Quote
Link to plug leads
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=270280441973
omega0684
posted on 17/5/09 at 08:17 PM Reply With Quote
you are correct, the leads in the link fit the second coil pack pictured
and
sorry but you can't use the ones in the link for a bosch distributer
i have a spare coil pack (second picture one) you can have with coil plug for £20 posted if you want. i think i have leads as well
[Edited on 17/5/09 by omega0684]
flak monkey
posted on 17/5/09 at 08:34 PM Reply With Quote
Its the newer sort as fitted to duratecs etc they have totally different connectors on the coil end. Best bet is probably pop into halfords and rifle through their leads until you find some suitable.
Either that or try getting one of the older sort...
Sera
http://www.motosera.com
dhutch
posted on 17/5/09 at 10:43 PM Reply With Quote
Right ok, so i have the newer of the two coilpacks, which is used on the duratec.
But the duratec being a dohc engine has plug leads that are unsuitable for a cvh, because they look like this.
http://www.pumabuild.co.uk/catalog/popup_image.php?pID=835
Seams like a bit of rummaging is required, or a trip to the scrap yard. For a diffrent coilpack and leads.
Daniel
mcerd1
posted on 18/5/09 at 07:30 AM Reply With Quote
you can get them made with what ever ends and length you like - there is normally someone doing it at the shows....
(sorry I don't have a contact, but I'm sure someone on here will)
[Edited on 18/5/09 by mcerd1]
