Stuart_B
| posted on 19/7/09 at 08:12 PM |
koso help
hi all, i was trying to fit my koso dash today, but i am stugling with the rev counter and water temputure, to get the rev counter to even read, i had
to wrap the wire around a ht lead, beacuse off the coil does not work. but when i set the dash to 4cycle and 4piston it does not read any where near,
i have to put it down to 1piston, to get it to read.
so any one else had this promblem and what can i do about it?
as well how does the water temp sensor work?
thanks
stuart
Mark G
| posted on 19/7/09 at 08:34 PM |
Is it an RX1N? If so then welcome to the world of hurt. Few people have managed to get these to read correctly. I have mine picking up of the crank
signal and the closest I can get to accurate is setting it to 12 cylinder.
As for the temperature gauge, it should just plug in. I had no problems with mine. What troubles are you having?
[Edited on 19/7/09 by Mark G]
richardh
| posted on 19/7/09 at 08:35 PM |
i went to 8 and 8 on mine to read right
R1 bike
Time for a change!
twybrow
| posted on 19/7/09 at 08:42 PM |
2s 3p for mine seems spot on (3 cylinder engine)!
[Edited on 19/7/09 by twybrow]
Mark G
| posted on 19/7/09 at 08:52 PM |
When you say 8 and 8, and 1 and 3 obviously you go 8 cyl and 3 cyl respectively, did you select 2 stroke or 4 stroke?
twybrow
| posted on 19/7/09 at 10:32 PM |
Sorry, I put 1 not 2! So I meant 2 stroke, 3 cylinder. I just played around with all of the settings until I found one that worked. Lucky for me I can
plug the bike ECU into my laptop and get the reading direct from the ECU to compare!
Stuart_B
| posted on 20/7/09 at 07:20 PM |
i have the all digtal unit, can not recal the name off it.lol
it is rectangle and lights up blue, if taht helps.
RickRick
| posted on 21/7/09 at 04:28 PM |
i've used the yellow black tacho feed out of the ecu on a 2004 r1 dead easy
