Author: Subject: OT Mondeo dash lights not working
balidey
posted on 30/11/09 at 02:16 PM Reply With Quote
OT, and asking for a friend, but this forum is the fountain of all knowledge.
Ford Mondeo, the dash lights have packed up, including the centre consol and stereo lights. All other electrics seem to be working.
He has checked all the fuses on the main board and says they are fine.
Are there any other fuses hidden anywhere, or would it be relay related?
Or does anyone know where these lights are connected, so we can possibly get to the plug to check pinout voltage?
Thanks for any help.
blakep82
posted on 30/11/09 at 02:50 PM Reply With Quote
ALL of the lights? inc warning lights, like brakes, abs, battery, oil pressure etc? or just back lights (like the ones that come on when you switch the sidelights on?)
________________________
balidey
posted on 30/11/09 at 03:06 PM Reply With Quote
Sorry, I meant the ones that are switched on with the sidelight circuit only. Warning lights are still OK
blakep82
posted on 30/11/09 at 03:21 PM Reply With Quote
sounds like the headlight switch to me then. or the wire that goes from it to the lights? i don't know how they're wired up
meany
posted on 30/11/09 at 03:44 PM Reply With Quote
do you know if he has checked both fuse boxes?.
balidey
posted on 30/11/09 at 03:50 PM Reply With Quote
Both? So where would the second one be?
meany
posted on 30/11/09 at 03:56 PM Reply With Quote
my PDF version haynes manual says
Main fuse box in passenger compartment
Aux fuse box in engine bay.
Fuse num 31 main box
7.5amp Brown
Instrument panel illumination
i dont have a mondeo myself but my wiring loom is made from one.
[Edited on 30/11/09 by meany]
meany
posted on 30/11/09 at 04:02 PM Reply With Quote
also.
fuse 34 main box
7.5 amp
Brown
Interior lighting and digital clock
meany
posted on 30/11/09 at 04:09 PM Reply With Quote
also from pdf manual file.
"The main fusebox, which also
carries some relays, is located inside the
vehicle below the facia panel on the
passenger’s side, and is accessed by a lever
behind the glovebox"
posted on 30/11/09 at 07:54 PM Reply With Quote
Dimmer switch turned down?
iank
posted on 30/11/09 at 07:58 PM Reply With Quote
Was going to suggest the same thing (been there, done that)
Anonymous
balidey
posted on 30/11/09 at 08:11 PM Reply With Quote
thanks for all the help guys, will pass on all those details to my mate
