Danozeman
| posted on 15/1/10 at 10:09 PM |
wiring wiper motor
Has anyone used THIS switch with mini wiper motor??
If so how do you wire it with only 3 terminals?
Dan
RK
| posted on 15/1/10 at 10:25 PM |
You use a relay or like me no park function. Search and you'll find it's a big topic of interest.
Danozeman
| posted on 18/1/10 at 08:36 PM |
a relay?? Anyone got a wiring diagram for this switch? Id like the park function.
Dan
| posted on 19/1/10 at 08:58 AM |
Dan,
I found this via Google - I have NOT tried it, and have no idea whether it would work.
LINKY 1
I've worked out something different with 2 relays - but I don't want to shout about that one yet as I haven't tested it!
Mine is a variation on this one - the diagram 3/4 of the way down the
page. I re-arranged it to use earth switching, to reduce the length of the power cables to the relays and wiper (and to make the wiring simpler). The
down-side is that you MUST use a car light switch - the type that goes Off - Sidelights - Sidelights + Headlights (normally listed as Off - On - On).
These are common enough, not expensive, and come in all sorts of shapes and sizes.
I'll publish once I know it works!
[Edited on 19/1/10 by David Jenkins]
