bodger
posted on 30/1/10 at 09:43 AM |
R1 2000-2001 Service Manual / Wiring Diagram
Has anyone got a pdf of the YZFR1 service manual 00-01 or more specifically the wiring diagram. The one I tried to download off the net has an error
when you try to unzip it.
I've got the Haynes wiring diagram but it has that stupid cycle-lock wiring added so you can't trace all the wires.
I chopped the loom up to wire up the car, most of it has gone back together fine but got a coupe of wires I'm not sure of.
There's a blue/black wire coming out of the ignition control unit and a blue/yellow wire from the relay assembly they disappear into the cycle
lock wiring on the haynes dia.
Any ideas ?
jack_t
posted on 30/1/10 at 10:12 AM |
if it is the relay box which should be black and size of a cigarette box and has like a clip on the back and a white plug goes into it
blue/yellow goes to the side stand switch (so ground it or use as a security device by putting a switch on it which the other end goes to ground)
blue and black stripe goes to the clutch switch ( so i have just grounded that aswell)
There is also a wire that comes out of that relay box that is black with a blue stripe which is the 12v supply for the fuel pump so make sure you get
the right one
[Edited on 30/1/10 by jack_t]
bodger
posted on 30/1/10 at 10:26 AM |
Thanks jack_t, I'll try that. Do you know anything about the blue/black/silver one that comes out of the ICU, I think it needs grounding as well
jack_t
posted on 30/1/10 at 10:30 AM |
take a picture of it and email it to me i cant remember a blue black and silver but if i saw it it might jog my memory
ill u2u u my email
maximill666
posted on 30/1/10 at 01:20 PM |
I can email you the Yamaha workshop manual wiring diagram, just drop me a u2u if you still need it.
bodger
posted on 30/1/10 at 03:27 PM |
Thanks I've just managed to find a copy on the net that works. Hopefully I can suss it all out now, thanks for the help.
