roy
| posted on 5/6/10 at 09:06 PM |
westy wiring help??
hey, iv just aquired an 1989 westfield 1600 crossflow, having a few issues with the wiring and wondered if any of you guys could help...
first of all i noticed the back lights dont work at all...
secondly when i put the side lights on the fuel gauge goes up to full...
and thirdly when i select either indicator the side lights come on!
i have checked all the earths i think and no problems there... maybe a crossed wire down the line??
i believe the engine and loom are from a mk2 escort so would appreciate if anyone could send me some wiring diagrams?
thanks in advance
Roy
gavin174
| posted on 5/6/10 at 09:20 PM |
Hi and welcome..
where abouts are you...
maybe someone local will come and have a look.
MkII
| posted on 5/6/10 at 09:32 PM |
have you checked all the earth connections your problems do sound earth related. .m.
RAYLEE29
| posted on 5/6/10 at 09:54 PM |
Hi, firstly all earths will be brown.
then you need a multi meter to check things.
clean the fuses and holders especially if its the original mk2 fusebox with ceramic style fuses.
Ray
JAMSTER
| posted on 6/6/10 at 10:13 AM |
i had a westie of that year and the wiring was the same as a mini 75-80 don't know if that helps. u2u your email and i will try to sent wiring
diagram from a newer westfield
:{THC}:YosamiteSam
| posted on 10/6/10 at 12:20 PM |
Ray
not all the time theyr not - mine has black earths or black/white
roy
| posted on 14/6/10 at 09:23 AM |
thanks for all the replys...
all the earths on this westy are brown as far as i can see...
the car is near howden on the way to hull...
