Author: Subject: flasher relay
dilley
posted on 13/10/10 at 09:26 PM Reply With Quote
flasher relay
Can someone please explain the difference between a motorcycle and a car 2 pin relay?
I have tried replacing my busa relay with an aftermarket item and it will not flash!!
posted on 14/10/10 at 07:57 PM Reply With Quote
Depends on the Relay.
A Universal Digital one (2 Pin) is the one to go for - any load (within reason) and automatically adjusts for 6v and 12v - maintains blink rate.
posted on 15/10/10 at 07:41 AM Reply With Quote
hmmm, no replies?
the flash rate of the 2 pin (using bi-metalic switch) is determined by the loading of the bulbs i.e. the wattage of the bulbs.
car indicators are 21 W but pretty sure bike one are less.
I tried to use a relay from a Land Rover (i.e. a car) on a Z1000 and no go - even though the bulb wattage was not hugely different, whci did surprise me.
2 pin digital? hmmmm not come across that; there are 3 pin which are independent of bulb wattage so can be used for LED lamps but need an extra connection to ground.
posted on 15/10/10 at 08:39 PM Reply With Quote
In reference to my posting above (and any doubters ) - we have one on the car and I got one for my daughters bike...
DIGITAL UNIVERSAL FLASHER RELAY AND INDICATOR BUZZER on eBay (end time 22-Dec-10 16:27:22 GMT)
Max load 60W
[Edited on 15-10-10 by Hellfire]
